Hi all,
I pulled a KV-75 out of my father in laws garage and started playing around with it. Had some missing pieces but I have sourced most of them. My big problem right now is the kickstarter. With everything together if I kick as hard as I can on the kickstart it barely moves. I have removed the covers on both sides and I can spin the magneto or the clutch basket and the piston turns, I can put a wrench on the oil drive nut and the piston turns. If I put the cover on and try and push the kickstart it does nothing, bolted down or not. I have pulled the cylinder and removed the piston and I get the same result. Clutch basket or magneto turns the crank, wrench on the oil drive nut turns the crank, put the cover on and push the kick start I get a ton of resistance. If I spin the magneto while pushing the kickstart, the kickstart will move but it is never able to turn the crank by itself. Yes the kickstart works and ratchets when mounted in the cover but not mounted to the engine. I have replaced the bearing in the clutch hub and checked that it spins only in the correct direction.
I have not split the case as it seems daunting, but I am running out of ideas. I have refrained from splitting the case since I can shift it through the gears and everything seems fine (drive gear spins when in gear), also since the crank spins well and when I removed the head and piston there was no side to side play in the connecting rod and everything seems to function as normal when turned by the clutch, magneto or by the oil drive nut with a wrench. I have even gotten it to spark by turning it with the magneto.
I have a video, I know you can't see the piston moving, but it is.
Video:
I have a few questions:
Any thoughts as to the cause of this?
should I be able to turn the large input shaft gear by hand?
When spinning the clutch basket or magneto, should the large input shaft gear always turn as well or just when the hub happens to catch it?
Thank you for reading and any assistance you provide.
Tom
Video:
Tom
