1 - 2 of 2 Posts
hoping that i could get some help splitting the case for my sons 99 KX 60, looking for any tips or tricks that anyone may have, i am trying to avoid paying my local dealer the $500 they want to split and install the new crank.
Also does anyone know where i can get a manual online?
thanks,
$500 to split the cases??? That is grand theft!:shock: When I did my sons KX60 I removed everything from both sides of the motor and the dealer here charged me $20 to split the cases. You can buy a timing gear puller AutoZone.com | Shopping | Accessories | Product Detail - Great Neck Timing Gear Puller and get the correct bolts which I believe are 6mm/100mm. Use the timing plate bolt holes and that end of the crank snout to split the cases. It comes apart as long as all the case halve bolts are removed. Here is a link you can read over about rebuilding a smoker motor. Honda CRM250R Mark 2 Engine Rebuild Project - A detailed guide to rebuilding an off-road two-stroke single
1 - 2 of 2 Posts
