The seal around the clutch actuator rod on my KX125 is leaking. I' ve heard that you can twist the rod back (opposite the way the clutch cable pulls it) to loosen it and pull it out to replace the seal. I have tried this, but the rod won't move. Is this the right way to remove it or is there another way?
Thanks.
Thanks.
