Hello all....new to this forum...i have a problem with my 2000 kx 250...i just had the bike tuned up from front to back. It started and ran fine a few times. Then it wouldnt kick over when started. I get no sound whatsoever out of the bike when trying to start it. Is it the crank, starter, carb, plugs, etc.? Any ideas? I dont know automechanics that well so bear with me.
AZ's Official Mechanic
pull the plug and see if you have any compression, if not then your piston/rings went south and it will need rebuilt.maybe the kickstarter mechanism is screwed up and not engaging the crank gear/clutch hub gear etc.... let us know what ya find out.
