1 - 7 of 7 Posts
hi guys, having a few dramas with my kx250f, it will die / stall out of the blue but it will kick start fine again straight after, I’ve replaced the spark plug, replaced the in tank fuel filter, removed and tested the engine temp sensor and the air intake temp sensor, I’ve also run the self diagnostic test and the amber light on the launch control flashes quickly and constantly, I’ve looked through all the codes in the manual and there doesn’t seem to be one to suit, any guidance would be appreciated. Thanks
Hi are the flashes long and short or all of the same length?
All of the same length and does not come to an end, it’s continuous. I’ve also disconnected the air temp sensor and run the self diagnostic again and the correct code flashed for that fault, this was just done as a trial to check I had the self diagnostic wired up correctly
1 - 7 of 7 Posts
