1 - 11 of 11 Posts
has anyone on the forum used anything but the factory drain plug gasket. I was wondering if a 10mm copper crush washer such as used on brake line fittings would work. I can't see paying almost $3.50 for a little crush washer at the dealer. Any thoughts? Thanks
i don't see any reason why the copper one won't work... asvlong as it seal's you won't have a problem... try it out..
Braaaaaaaaap
Yes it'll work. When I got my kx 80 it had a regular washer. But I eventually changed it because the washer came with a gasket kit I bought.
If you want a really nice drain plug...get a moose racing one with the magnetic tip.i have on and it works gret you wouldnt believe the little thing it pulls out.it come with washer and all.
It was 12$ pretty good for a plug...Its has a super stong magnit on it very nice.
Well....if i change my oil(witch will be soon)i will take a pick to show you the stuff that it picks up.
i added you as a buddy on here just go to my profile and so that...we can send messages.
1 - 11 of 11 Posts
