Ok! I'm cheap, Why is it that you buy smaller shims @ $10.00 each instead of thinning up the ones that you have? It seems like taking a mm or two off would be the answer?
That is funny from a techncial aspect. I would go with spending the money for new after that comment!It seems like taking a mm or two off would be the answer?
Well you gotta admit, the chances of ever having tight valves again would be pretty slim. :wink:That is funny from a techncial aspect. I would go with spending the money for new after that comment!
Theyre $5.28 at Z1 Enterprises, just a "click" away.Thanks for the replies. As for uniform, not that hard to do and you would only take material off the back side. It's 120 miles to the first kawasaki dealer and the only local bike shop didn't have any 29mm shims. I asked to see if it was a common practice or not. Have a great day.
Well you might as well include the plans for drilling for oil and mfg gas once that civilization breaks down too. :lol:Now should civilization break down and you cannot get them ...well now you know how to go about it. :tongue:
When civilization falls, the only "shims" Ill be grinding will be called "horse shoes" Mankind arrived into modern civilization riding a horse, and will ride a KZ-1000 out of the collapes of modern civilization! Mad Max!Well you might as well include the plans for drilling for oil and mfg gas once that civilization breaks down too. :lol:
Whats up Hillbilly? wont that bike run on liquid corn?When that happens there will be plenty of gasoline left in all these cars as many people will die fighting each other. I have not seen a futuristic movie yet where they had to drill for oil.![]()
10% corn right now is screwing up the carbs so 100% would be a negative I assume you old *****. :lol:Whats up Hillbilly? wont that bike run on liquid corn?
Oh thats good Paul, thats just dandy!:lol: If you leave the corn in the jug until "after" you work on the carbs, I think youll find its not near as damaging....to the carbs that is! :lol: Ridgerunner!10% corn right now is screwing up the carbs so 100% would be a negative I assume you old *****. :lol:
You mean to tell me you haven't seen the mad max series?When that happens there will be plenty of gasoline left in all these cars as many people will die fighting each other. I have not seen a futuristic movie yet where they had to drill for oil.![]()
Corn is gooood! Come and get it! Better dress warm though! Below 0 again tonight, and the wind never stops blowing in Nebraska!If you want to share some of that corn, I could use some help on the shim change.
I've got a quart sitting on the desk right now but I'll warn you up front, it's more than 10%. :lol:If you want to share some of that corn, I could use some help on the shim change.
