1 - 1 of 1 Posts
Kawasaki Z440 Z400 twin, 2 into 1 inlet manifold with carb .
Made from new 42mm copper pipe fittings . includes a used Keihin Flat side carb (from a CR250 Honda ) and link hose. The set up puts the carb at 90 degrees to the engine as per last pic.
Currently set up to fit the Z440 - may need some extra trimming to fit the Z400 as I believe the head is slightly different.
The carb may need rejetting to suit however I will ultrasonically clean it before I dispatch it.
The fittings do need soldering together which i can do if required. ( For Z440 only ) . If you want this for the Z400 I suggest it come loose so you can match it all up.
any questions or message me with email for pics .. please ask. £95 + Post
1 - 1 of 1 Posts
