I have some serious issues on the clutch/flywheel/starter.
mainly flywheel/clutch gear not fully engaging to turn the engine over in complete revolutions , it will lock up on the clutch/flywheel and atempt to turn the engine over and then it "pops off" and just spins freely until it catchs and locks up again then pops off as it attempts to turn the engine over. the starter is good (just replaced). It appears that the mounting bolts that attach the clutch to the flywheel have sheared off.
Anyone know how to remove the flywheel? The manual says to use a rotor puller (which I don't have) but it doesn't say how the puller works?
Is there a way I can pop the flywheel/clutch off without the puller??
