Hi there,
I have a 1980 KZ750H1 and at the end of last year it developed a slight ticking sound. Since then it sat around over winter and after I cleaned the carbs, I fired it up and brought it back. Now the ticking sound is a bit louder and it increases with the rpms. I'm guessing it's the valve clearance and was going to pull the head cover off this weekend.
One question I have is I've been reading a bunch about valve adjustments and it sounds like the valves get tighter over time, not looser, however the ticking sound would indicate loose clearance. What else could the problem be here? What else should I check while I have the head cover off? Also, which gaskets am I going to have to definitely replace? I figure I'll order them ahead of time and try to get this back together quicker. The bike's got around 25k miles on it.
Thank you
Thank you
