I'm not totally clear on the nasty streets thing, but I doubt the slight width increase going from the 100 to the 110 will do much for you. I will say if you still have the rib style front tire versus the general tread style where the back is a bit closer match to the front, the rib tire will want to track with cracks and road grooving more so. I also think you may find the newer 100 to be maybe a bit wider than the old ones.
If it's serious "floatation" you want, what you should do is spend a bit for some spokes and lace up a fat 16" front wheel to run a 120 or 130 front tire like the Classic models have. Handling will suck, but it will be more tolerant of the rough pavement.
Otherwise start looking where you want to go, between the bad stuff, and not at the bad stuff. You WILL go where you look. Practice it. You can look a few inches to the side of a hole or patch and you will go there. I learned this in trials riding. You never look where you don't want to go, look where you do want to go.
