1 - 11 of 11 Posts
my kawa when i put gasoline, it throes by the "exess hose" , but the tank is not near to be full!
what could it be?? the tanks is pretty empty but when i put some gasilien it goes directly to the exess hose.. =(
help?
m no.. the gasloine is passign thru the carbs very well.
but for some reason.. is like every tear ogf gas i put it goes directly to the exess hosee back the tank.
carbs don't have a return fuel line. they dump excess fuel on the ground. have you checked the float valves in the carbs?
is not leaking from the Carbs nor its components at all.
its leaking fron the Tank exess hoses that goes back of the tank. those hoses are to evacuate vapors or exess of gass as i know..
The carbs are perfect.
but i have no idea what could make this happen if the tank is not full yet.
1 - 11 of 11 Posts
