You could try retrofitting with a newer headlight. Or try a brighter aftermarket bulb.
OEM = Original Equipment Manufacturer.What is OEM ??? I'm new and I keep seeing this being used. Thanks in advance.
Your owners manual will show you how to adjust it to the right height....Stupid question, but do you have yours aimed high enough? My light was aimed pretty low from the dealer.
+1^^^ I used this bulb on my Wifes 06 900LT and it's quite a bit brighter. She seems to love the difference.NAPA, Part number Wagner Lighting #BP1210/H4 bulb ($12) will make a big difference. It is even endorsed by Rich. On my 500 the new low is now as good as the OEM hi was and the hi is as good as my cage.
There's quite a difference btw the headlights of the 1500 Classic carb and FI models thanks to the big multi-reflector headlight -- which is not used on the standard Classic.Rode my gf's '07 900 yesterday and discovered what it's like to have a headlight. The one on my '96 1500 sux.
