1 - 10 of 10 Posts
I'm trying to loosen the bolt for the clutch basket on a 89 yz125 that i'm going to part out. I took a small gear off the transmission to stop the transmission from turning so i can loosen the bolt. It seems to be on really tight i'm using a 1/2 breaker bar...
What is a good less expensive air impact wrench to buy? Does that work good for loosening tight stubborn bolts?
Sears sells an electric impact driver that worked wonders on my 1600.
If you don't have access to a compressor, that's the only way to go... probably be able to rent one for $20 or so, you're only going to need it for about 30 seconds.
I had limited luck using air tools with my 1.5hp compressor... they simply don't have the CFM to operate anything much larger than an air ratchet. Mine wouldn't even spin a die grinder.
If your regulator is set anywhere @ 90psi or higher, any gun will zip the nut right off. A good basic air tool kit is the Campbell-hausfield kit from Wally-world; 1/2" impact, 3/8 ratchet, and some other stuff. Just be sure to use a good 6 point socket to avoid slipping or stripping the nut.
DO NOT use it to put it on. Just use a dab of blue Loctite and get it as tight as you can by hand using a 3/8 drive ratchet, not a 1/2 drive or use a Tq wrench to specs. Have a friend help. He can hold the basket by wrapping it with a rag to keep from tearing his hands up and get a better grip. Or you can invest $60 for the tool. (I use the friend mod).
my regulator is set at 110 right now and that seems to put out a pretty good burst of air. I haven't used any air tools with it but i'm going to try out an impact driver i need a better way of breaking tight bolts loose...
from what i can tell if you get a 1/2 with 230 or 250 ft/lbs on up it will probably do ok...
That will be more than enough due to the fact of the hammering action the gun uses. I have many pro tools like an IR that has 1000ft-lbs-reverse but turn it down to it's lowest setting, and a large compressor still regulated at 90psi and it still rips off any nut on a bike.
If you run any air tool at high pressures, it's actually bad for them. Always use an air tool oil, WD-40 if nothing else. There's lots of moisture in compressed air and your tools will rust inside.
thanks for the advice...i'll set the regulator at 90psi and try it out. I've read that the IR 231 is a good impact wrench for the price. I'll probably try out one of the cheaper northern tools that has 250 ft-lbs since it has good reviews...
Discussion Starter · #9 ·
I bought a craftsman 1/2 impact wrench 340 fl/lbs max got it on sale for half price $19.99 and it worked great to loosen all the bolts. My compressor is a 10 gallon 1.3HP [email protected] psi and it worked good. The impact wrench has 3 torque setting for both forward and reverse which is nice...here's a link to the wrench i bought for half price it's a great deal
Craftsman 1/2 in. Impact Wrench - Model 19982 at Sears.com
I got a snap-on 1" air impact wrench for £25 but its useless on my 20gal 1hp compressor (OLD compressor) its worth if you can getting an idustrial size compressor like my work have (undoing wagon wheel nuts with a 2"1/4 is main job)
1 - 10 of 10 Posts
