Hopefully someone can help me with the problem I am experiencing with my 2005 ZZR 1200. The bike has 2,200 miles on it. I bought it 4 months ago with 1,040 miles . The bike looks like it is brandnew. It runs great. But about a month ago it started hesitating at 2000 - 2500 RPM. Like one or 2 cylinders aren't doing their job. It sputters. It pulls through easily. The more throttle I give the quicker it goes past the critical area. And the bike has plenty power anywhere over 3,000 RPM. Gets up to 170 MPH in no time. When the engine idles, it is not as stable, as it should be, but it never stalls. Running the RPM's up from idle, with no load on it, is OK. It speeds up immediately without hesitation.
It felt to me like the slow jets could be dirty. The previous owner had it sit still for about 8 months.
I put GUMOUT in the tank a few times. Did not help.
I cleaned out the carbs, twice now.
I did find just a little dirt, the first time, but nothing bad. I blew out all jets and air passages. Cleaned and adjusted the sparkplugs while I was at it.
All my labor resulted in no improvement.
Is this something electrical? Like maybe a problem in the throttle position sensor? Ignition timing?
Hopefully someone has an answer before I take it to the shop.
I love this bike and it needs to run the way it should.
Peter, Houston TX
2005 ZZR1200
Peter, Houston TX
2005 ZZR1200
