1 - 7 of 7 Posts
I a little too short to sit flat-footed on the 1600. I like the factory seat and don't want to replace it or shave it. Thinking about lowering. Any suggestions on how to do that or on kits?
Custom '07 1500 Classic
Thanks, many options available through them. Do you happen to know of anything else that isn't so expensive?
The safest/cheapest way would be to have the seat reworked. It's fairly easy to drag the floorboards once you get used to the bike, there is a guy in Fla. I've heard some talk about on here that does seats for around $75, much cheaper than any shock mod you're going to find. BB
Luv my big boy toys
Mean City Cycles reworks your OEM or aftermarket seat. They can replace the foam w/memory foam, shave the height. They can add a heater, change the "pleather" to genuine leather, fancy stitching or even fancy designs.
+10,000
Ground clearance on Vulcans is bad already. Lower the bike and you'll be sorry if your riding involves anything other than a straight line.
Have the seat shaved. It can be shaved and reworked for half the price of a Progressive Suspension setup and won't negatively impact ride quality or handling.
I think I will try shaving the seat. I had an additonal 1 1/2 soles added to my boots, but it is clumsy to walk in and harder to shift or brake. And it looks goofy.
1 - 7 of 7 Posts
