1 - 10 of 10 Posts
Wind is good
I'm mounting a small tach on my bars. The mounting kit is plasti-rubber
and it's for a 1-1/4" bar. I need to add some spacer to make it fit. I
was thinking a material, just a strip of cloth to extend it out? Other options?
Slow Guy on a Fast Bike
May sound like a ******* remedy, but I used electrical tape one and it worked fine. It was narrow enough to almost be hidden under the clamp and not be noticed at all.
Shade-tree mechanic - ******* - cheap guy fix: beer/coke can cut in strips the width of the bracket.
Elmer
My first thought was rubber innertube or conveyor belt. The PVC that rfb92345 mentioned was interesting. How about just a couple inches of plastic tubing from the hardware store or a short piece of heater hose from the auto parts store ... clean, cheap, quick, non slip, and waterproof.
How about you tell me how wide you want it and i will make you a stainless steel split bushing for it. You pay postage and it is yours..
Machinist For Sale/Rent
Stainless is pretty and won't ever rust but, it can and will cause the chrome it is sitting on to rust.
Wind is good
Discussion Starter #10
I found some rubbery coated fabric from a hold down and that spaced it out enough to make it attach solidly.
Thanks for the tips, all.
1 - 10 of 10 Posts
