1 - 5 of 5 Posts
I gotta 93 kx125 and i noticed the trans oil was milky so i changed the two waterpump seals and replaced the bearing and gasket. I rode it for a while and got the same problem. Can anyone give me any suggestions? Thanks.
Have you checked the seal at your kickstarter and the clutch? If the waterlevel in your cooler isn´t dropping you can rule out the possibility of leaks from the cooling system.
If you use a pressure washer to clean your bike it´s possible you got the water in that way.
MILKY
Although my bike is not water cooled...the guys were telling me tha twith mileage or even just racing that some people rebuild their bikes every 4 or 5 races...sounds silly to me...but, if you have some serious mileage on it it wouldn't hurt to take a look on the top end to see just what you have and replace the gaskets as you would have to anyway. Then you know what you did and when it was last done...
Was it milky after you changed the oil?
Does it run ok?
Is it using rad fluid?
If not, change the oil more often and keep running.
1 - 5 of 5 Posts
