I figured I'd make a channel on the mIRC network I am a part of. This is good for general convo's and possibly instant answers if I or someone else is around.
Also check out #ghostchat for non-motorcycle related topics.
Pick a nickname and a alternative
click ADD
enter this information, you can call the server whatever you want
For the server info use 'freakinout.ghostsofirc.net' or 'freakinout.dhs.org' port '6667' (take off the ' ')
Click Perform and make sure the checkboxes are like mine
Enter this info in the perform, but replace Freakinout with your nick, and password with your password that you registered with. I'll give you the command line of how to register at the end.
make sure these checkboxes are the same as mine.
To register your nick go through the first 3 steps, then register by typing
/msg nickserv register password
that should work flawlessly, then go back and finish the rest of the steps and you should be good to go. Please PM or e-mail me, or aim, or any of the other mIRC gurus on here.
click ADD
