Is it normal for a 1988 Kawasaki Mojave to start up with 15+ kicks when it's 50-0 degrees. If not what is the normal amount of kicks.
20lbs? I can see how that would be causing problems. Glad you found a fix for it.Kawa mojave said:The spark plug wasn't the problem at all. I took the valve covers off and discovered the last owner didn't tighten the bolts that keep the intake valves in place. The bike was running with only 20 pounds of compression
Thats about like me telling you I have a car thats white, then asking you what year/month did the first one roll off the assembly line? Read this thread and try another question please.i have a mojave 2 and i cant seem to get it to fire could anybody give me some ideas
