I have a Kawasaki mule 1000 that is only firing on one cylinder. The coil is good b/c I can change the wires from the other one and it will fire. The wires going to the igniter box are in good shape. Any thoughts
Ummm sounds like your Igniter :(
Make sure the wiring to the coil is definitely good.
Check for feed to the coil and a ground circuit when cranking the motor..
after further inspection I noticed that the relay circuit that goes to the fuel pump was not working. I put on a new one and it didn't work either, I noticed that the relay wired into the coil and igniter.
