The diesel engines are Daewoo. However, Kawasaki uses the turbocharged version without the turbo to get the correct crankshaft strength for Mule use. Briggs and Stratton now sells the engine in the US, just be sure to stay with the turbo version then use the fuel injection pump from your old engine, or you will snap the crankshaft if you cut corners and try the lower cost unit.
