I have a 2008 mule and the metal brake line that runs under the seats rusted through. Is it possible to repair or does that need replaced. I’m also having trouble finding a replacement if that’s the route I need to go. Thanks in advance
I was able to get the same size and fitting line from auto one and just replaced the entire line. Thanks for the suggestionsIf you carefully remove the entire line, you could take it to a shop that repairs brakes and ask them to use the old line as a pattern to make you a brand new line. If they won't do it, try a hydraulics shop.
If that is not possible then rv7charlie's fix might get you a few more years before the line lets go somewhere else, but of course when it comes to brakes, I would personally replace it with 100% new.
Murphy's Law dictates that the brake line will blow when you need it the most.
It’s roughly 80in long and autozone only had two 40s so I needed a connector which added an inch or so which gave me a little slack which I bent to use up. It’s completely straight though until it bends up behind the pedals and then a few more bends to get it to the master cylinder. Pretty easy job though aside from all the screws that need removed to get the center panels out of the floor, which meant removing all the plastic trim pieces under the seatsThanks for circling back to the forums to let us know how you made out. Glad to hear of your success. Was it mostly a straight line or were there any tricky bends?
