1 - 2 of 2 Posts
Greetings,
I overfilled the engine with oil (didn't realize there are 2 drain plugs). It has smoked unburnt diesel smoke ever since. Took it to a backyard mechanic who is trying to get the pan off (assume a bent rod or messed up bearing on the middle cylinder which does not come up to TDC). How do you remove the primary and secondary clutches??? I understand there is a specific tool. Does anyone have info on the proper tool to get and where to source it from??
Thanks,
Keith
I'm struggling with the same thing. I need to remove the drive clutch from the crankshaft (I assume), and can't get the bolt out of the end of it. I upgraded to a 700ft lb impact, and still nothing. What's the trick?
Thanks!
-Ben
1 - 2 of 2 Posts
