mule 3010 needs starter. How to remove ? new or rebuilt ?
33K views 5 replies 5 participants last post by  imported_cookie_monster
#1 ·
I have '02 Mule 3010 4x4 that the starter is going out. How hard is it to remove ? can I have the orginal one rebuilt ? where is the best place to get a new/rebuilt one ? Thank you in advance!
#3 ·
the starter is something like $450 from Kawasaki. Maybe closer to $500. On ebay they're about $120 give or take-just installed one on a friend's 3010 Trans. Worked perfect. How long it lasts is a good question but it works-for now. If you can get the Mule in the air a few feet (a lift is nice)...it can be removed somewhat easily from the bottom, in bettween the engine and gearbox. Kind of tight but it comes out. 4" extension 3/8" drive ratched and a deep 12mm socket is all you'll need. And plenty of patience :)
#5 ·
Cookie Monster is right and has a good fix on another thread. I modified his approach below.
I have a 2004 Mule 3010 and I removed my starter in 5 minutes with a 12mm flex gear wrench. The wrench cost me $8.
I did the same thing as Cookie Monster, but used the ratcheting end of this wrench.
1. Place the ratchet end of the wrench at a 90 degree angle.
2. Put the ratchet end on the bolt, but do not try to turn the bolt with the wrench. You will round the corners if you do.
3. I placed a metal pipe (wood dowel may work) on the ratchet near the bolt and gently tapped it with a hammer from below.
4. The bolt was loose immediately and I backet the bolt out using the ratchet end.
Good luck.
