I read a bunch threads reporting the same problem but not one came up with a resolution, assume they fixed the problem.
Working on a 610 seems like lose power only when going up hill, feels like its bogging or starving for fuel, engine does idle if I let off on the gas peddle and it will regain power after 4-5 seconds but does it again after a few hundred yard. Some said replace the fuel pump with a 12v fuel pump but it never said if it actually fixed the problem.
What I know so far,
Valve adjusted, good spark, good battery
The carb was cleaned multiple times, OEM pulse pump and fuel filter was replaced, lines are clear.
Gas cap seals tight, good fuel.
Any idea what to troubleshoot next? TIA
What I know so far,
