My 2008 610 4x4 with 66 hours has had a number of issues over the winter.
First it started to die on me and then ran rough and only with the choke out.
Our winters are very cold (-35C) so I started using gasline antifreeze. This helped I think.
Then the mule kept popping its oil filler plug off when running and now has started to spew oil from the vent on the top of the fuel pump.
It seems to run fine at the moment except for the oil loss but I assume something is blocked or frozen.
The schematic of the fuel system shows a crankcase breather tube to the pump but is the "breather - #14069" a one way valve?. If so is it allowing oil from the engine to be sucked into the fuel pump ???
I would really appreciate some help before the engine seizes !
Thanks dave
Thanks dave
