I Have A Kawasaki 2510 Mule Non Diesel And Can't Get It To Start It Was Running Good For A Couple Hours And Then Was Shutt Off And Would Not Start Up Again. I Have Pulled The Plugs And Grounded Them Out And They Seem To Fire Very Well, When I Pulled Them Out They Where Very Wet So I Would Assume They Are Getting Plenty Of Fuel. I Did Hook Up A Compression Gauge And Check The Cylinders And One Was 60psi, The Other A Little Lower. I Don't Know If The Engine Has Automatic Compression Release Though.
