I have a zn1100 b-1 an have rebuilt the carbs new diaphrgams ,air pilot jets etc , I did not sink them in carb cleaner but did completly dismantled an cleaned
all passages .but because it is a us modle it has a plug over the air idle screw an i want to remove this so i can clean that passage
1)how do you get the plug out with out destroying the thing or the getting
fileings in the carb p.s. do you need the plug ??
2)i think this is my problem because it is running real rich & it is blubbery& sputtering when i put the carbs back on an started it .
3) i did not put in new needle valves an the plastic spring seat slide in to the new diaphgrams tight should the move freely
4) should i replace the needle jets an the float bowl jets etc.. i was told an have never heard of them going bad except with high mileage wear..
all advice would be excellent . the season is here an i sold my 2nd bike so this is all i have to ride
thanks fenny777.
thanks fenny777.
