My 1990 600R has been down now for almost a month. I tore it apart to re-jet the carbs, (dynojet stage 1 kit), install a Muzzy 4 into 1 system, and install a new radiator that was leaking, and all corroded. I finally got my Muzzy system from Parts 411, TOOK 3 WEEKS to get it from them!.
The **** exahust does not fit properly :evil: The midpipe hits the right lower rear corner of the frame, no matter how you orient it. It clears fine, until you go and put the can on, and attempt to line the can flange up with the hanger to put the bolt through. you have to put pressure upwards to get the the hole to line up, then it pins the midpipe up against the frame.
I tried every angle..............really upsetting. I had Muzzy on the phone several times. I ended up sending the system back to Muzzy directly for them to evaluate, and figure what the heck is going on. IT just doesnt fit plane and simple.
Meanwhile, my radiator shows up, but I cant install that until I get an exhaust system back here............
I should have just waited till winter, the weather has been great for riding, and my bike is sitting int he garage in pieces waiting on parts......because I could have just rode the rest of the season, even with the radiator.
I just keep hoping it will be worth it in the end, when its all done and ready to roar. I picked Muzzy based on their great quality and fitment, and I get a system from them that doesnt fit...............
Sorry guys, I just needed someone to complain to
Your thoughts are welcome
