1 - 5 of 5 Posts
When I put the key, this have no power, no electricity, no nothing. I check all the fuse, the battery and all look fine. Any help?
you stated you check all the fuses. Some bikes have a main fuse separate from the others. Did you look in your manual to see if this is the case.
The problem was founded. One of the cable that go to the switch was disconnected. This was re-connect it and wala, problem solved.
1 - 5 of 5 Posts
