I picked up a 2510 4WD Mule from a friend that is getting coolant in the crank case,When I pulled the heads to replace the gaskets I found the block is cracked/eroded through. Where is the best place to look for a replacement engine or manbe a short block?
I also need to finding out the age/model number of this mule, the s/n plate on the front is mostly illegible I can only make out JKIAF, there is a sticker under the steering column with KAF602A.
Thank for any info I can get.
