1 - 4 of 4 Posts
The rod snapped on top of the piston so I have alot of work to do.
It is in three apart on the bench. bottom, top, and cylinder is junk.
I need to get the cases apart now and Need to know what special tools do I need to get at the crank and rod.
What is the best puller to use?
Gotta get this block apart to start cleaning.....
Sorry to hear about all the damage.
I'm not familiar with the engine but maybe you could call a local shop and ask the mechanic the same question? Just a thought.
Good luck!
You need a KX250F flywheel puller :
Motion Pro - Flywheel PULLER, M24x1.5 R.H. Internal Thread
And get youself a real OEM Kawasaki service manual if you don't already. You have a huge mechanical task ahead of you, so don't skimp and try to rebuild from "memory" You are going to be into this rebuild for about $1000 in parts alone ($500 more if the head is trashed). I rebuilt a buddy's 2002 YZ250F that siezed from lack of oil change maintenence. And it was $1660 in parts !!! Welcome to the ugly world of 4 stroke engine failure. 4 strokes are the best thing that happend to motocross,( until when they granade )
Sweet thats the tool! Though it only lists it as 04 and 05 kx 250f not 2006 ??
I was watchn a utube vid on it and he was using a great big puller?
I got my parts list. And it is gonna cost a few buck, but worth it.
1 - 4 of 4 Posts
