I have a mule 1000 and am having poblems with an intermittant warning buzzer at various speeds. When it sounds the motor cuts out for as long as it is sounding. I have check and repaired some wiring in the harness under the floor boards. No difference. Checked the speed sensor. I get continuity 4 times with one revolution as the manual states. However I get about 6 ohms of resistance when in between the continiuty cycles. Is that correct or should it read infinity?
When I check the igniter with my ohm meter I get really hi (mega ohms ) going from no1 terminal all across the the rest of the terminal. From no2 terminal I get hi readings also but most a K ohms. Nothing like what the manual say I should be getting. It is not a kaw ignitor but is a Hitachit Ltd. TID12-26
1231 sn 8713
Digital ignigtor.
How much is an ignitor and or the speedometer?
Also any addition trobleshooting tips would be appreciated.
One more thing if I unhook the speedometer cable it runs fine but the warning buzzer sound almost constantly unless I slow to almost idle speed.
1231 sn 8713
Digital ignigtor.
