1 - 4 of 4 Posts
Wondered if anyone could tell me the timing marks or specs for a kawasaki 400 Bayou ATV 2X4? There are 2 lines and a "T" for top dead center(?) on the crank-one line on timing gear. If I put the line on the timing gear straight up and use the "T" on the crank as Top Dead Center, I have compression coming back out the intake valves. I did a "Leak Down" and there are no bad valves. I do not have a book/manual so would appreciate help. Thanks! Jim
How are you doing? just wondering if you ever ahd any luck on the timing marks im have the same issue.
1 - 4 of 4 Posts
