Carbs Air/Fuel mixture Screw....Unless
Unless your bike Has an exterior Adjustment or you Want to Rejet it ...But Id check the Manual It should Have higher altitude Information right in it.
This is just coming from automotive experience so take it for what its worth, but the problem is the same volume of air running through the carb having a lower concentration of oxygen due to the higher altitude. You need to lean out your fuel mixture. I don't know much about mules so I can't really tell you how to do it on your particular carb but thats the gist. I'm sure someone here (or the manual) will give you the info you need.
