Hi my name is tony im from Rhode Island and im new here i have a 99 nomad that just had the pog replaced at the dealer 2 weeks ago when i picked it up the neutral light would not go on and the bike would cut out when letting the clutch out even when in neutral , with research on line i thought i had figured out that the switch had gone bad cause if i grounded the wire the light would work and the bike would stay running so i replaced the switch with new one and i still have the problem so my question is in, the case what pushes on the switch to activate it ...and would a weak clutch spring cause this problem? thanks in advance all help is appreciated
tony
green on green 99
tony
green on green 99
