1 - 16 of 16 Posts
Just Getting Started
I was thinking about doing a complete debaffle job on my 2007 VN 900. As I read over all the posts I heard of people trying not to mess up the pipe while using a Sawz All to cut the pipe. I came up with a great way to cut my pipe without any damage or having to work around the end caps. I don't know if anyone else did this but I put a Dremel with a 3/4" cutting plate up the pipe and cut it off without any issue. I did go through a couple of the plates, but it was sooooooo easy. Stop messing around with the Sawz All.
Snowmobile,
I have the same bike and have taken the oval disc off the rear of the exhausts. I have been trying to think of an easy way to remove the plates that the discs are pop rivetted to. I think I will buy a dremel. It could come in handy in the future. I have already drilled out the 4 plates up both of the exhausts. How does yours sound ?
Magpie
Discussion Starter #3
It sounds awesome! I did the complete debaffle so it sounds like many others, you can find the sound bites. I just found a different way of getting the pipe down to the baffle. Good luck!!
When I did the Stage 2 on mine, I used my reciprocating saw with a blade for metal and while I was indeed careful, the fact that I generously covered the surrounding pipe with lots of painter's tape helped the few times that the saw jumped on me! :biggrin:
Discussion Starter #7
I used the hole saw as well, but it came later. I used the dremel right after i drilled the rivets out and took the end cap off and needed to cut the pipe down to the baffle.
Not having a reciprocating saw I took a hack saw blade and shortened it, ground the end to fit in a jig saw I had, and did the necessary cutting.
I bought the Great Neck rotary tool from AutoZone..best investment I have made. Make sure you buy one with the cord..the cordless Dremels run down too fast.
T.O.
Decided to do Stage 2 on my 2007 VN900 Classic today. Went to a mates work while he was doing a bit of overtime , borrowed his small air reciprocating saw, broke off a 4 inch length of a new hacksaw and 10 minutes later the ends were off. Five minutes and 16 holes later the job was done. All I have to do now is spray paint the inside of the exhaust end and happy days !. The sound is a lot better. Wish I had done it ages ago. Attached (if it works) are photos and one of my stock bike.
I didn't spray mine after a while they turn black form the exhaust fumes.
I tried the Dremel idea when I debaffled mine, and after going through many of the hardenened cutting discs, I used a shortened hacksaw blade after removing the rear covers. The hacksaw blade worked better (no sawzall) and was less frustrating.
My hat is made of tinfoil
Easier yet, just unbolt the pipes completely and toss them away.
No need for anything more than the header pipes.
Hey why give a **** how much noise it makes.
If you watch south park you can see ideas how to make a bike even louder and more annoying to **** off everyone........not just the 99% of peopel it will make mad already.
woohoo.....................yell and scream while ya ride it to...............adding a train horn is cool as heck to.
and every 300 yards light a stick of dynamite and toss it for extra noise.....never can get enough I tell ya.
Discussion Starter #16
Not a problem in Utah. They only do safety inspections to make sure your brakes, horn, and lights work.
1 - 16 of 16 Posts
