1 - 6 of 6 Posts
Did not fancy the idea of the big gap between the fender and tyre when you replace the front with a 120, so here is my replacement fender from.....believe it a 250 Hyosung with some mods.
That looks hot, did you have to do any modifications or did it bolt right up? I noticed a bracket or part of the old fender removed. do you have you repolish your rims often? GOOD JOB!!!
Discussion Starter #4
I made an aluminum bracket that I polished, some parts were cut away and closed the holes on the side where it normally will bolt on to a superbike - will take some detail pics. The wheels I had done about 2 months ago and so far I needed no additional elbow grease to keep the shine - I think you might have to repolish them once a year.
Yea, that fender looks like its a factory item. Any one knows a shop in los angeles area that could do some polishing?
1 - 6 of 6 Posts
