1 - 7 of 7 Posts
Just got started bobbing a '81 KZ440ltd, and want to weld on a hardtail. My question is, does anybody know the inside diameter of the smaller frame tube? I want to put some roundbar slugs inside to stiffen the welded areas. I'm hesitant to cut the frame until I know I can get a hold of material to finish it. Thanks in advance.
Welcome. Hope some knowledgeables would chime in. Or post in the tech section
Thanks for the welcome. Went ahead and chopped it. It's just about 7/8" ID. Got some free sucker rod from the machine shop that will fit with a little grinding.
Super Moderator
Rather than grind, why not have the machine shop take a skim cut on the rod with a lathe, and produce a perfect size with perfect roundness?
It should not cost much as it would only take them a few minutes to do this.
I thought about that, but the problem there is that the frame tube is out of round and has a seem inside that I can't reach to clean out. It'll take a while but im sure I can get a good fit.
Super Moderator
And I suppose if you used a 7/8" reamer in the tube it might weaken the tube. A judgement call. You seem confident on a good fit with a grinder.
But on another topic, does your bike have belt drive?
Nope, chain drive. Worth noting too that im making this **** up as I go, and this isn't going to be a daily rider. I've got a bike to ride, this is just something to stay busy with in the garage. Thanks for the input tho, I'll think about that.
1 - 7 of 7 Posts
