1 - 4 of 4 Posts
CableRat
:confused: 1996 kawasaki vulcan 800a
leaks oil at base of engine,prob less than 1/2 teaspone in a day.
would a good engine sealer work? or should it go to the shop?.
i have the upper engine gasket kit to fix this problem
Thanks
[email protected]:confused:
CableRat
Discussion Starter #2
Guess i had it wrong,that was what i was told by previous owner:oops: -[jug base gasket}:shock: should have been called top end kit for vulcan 800 .
Is it a big job to change thease gaskets or is it somthing to take to shop for work to be done.:confused:
thanks,
opinions needed!:mrgreen:
[email protected]:biggrin:
If it's the actual base gasket, then the whole top of the engine has to come apart including the cylinders. Not difficult but a lot of work. If it's only leaking that much and you can tell where it's coming from, you could try pushing some sealer in there as a temp fix (probably won't last permanently) until it gets worse. Silicon doesn't like oil (regardless of what the product says) so try something else.
1 - 4 of 4 Posts
