Joined to search for zn1100 information. The bike has about 4,000 miles and I just cleaned and set the carbs. It actually had one main jet packed with black sludge chunks. First time I had a main fully blocked. The idle jets looked like they had float needle tips poking out of them lol. The throttle plates looked perfectly bench or factory synced. (Plates bisect first hole) I did not check with my gauges. Idle mix screws 2 2.5 2.5 2. Started right up once I put the cdi ground back on lol. Idles and revs flawless and sounds extremely healthy excluding a quiet/soft slap or clash noise that seems to be coming from the middle of the engine case at random times during the brief period I let it idle. I revved a few times to 4,000 rpms and didn't notice the noise or anything else bad. Reminds me of random and soft tappet noises in a random pattern but it's slightly louder and not coming from the top of the engine.. I don't think. If anyone has any guesses or had a similar situation and discovered the cause please share with me. Maybe I didn't tighten the intake rubbers enough? I feel like it would have a lean symptom somewhere in the rev range if that was the case and not a soft split second starter clash noise at random times during idle. Who knows maybe it would go away with an oil change and running the bike. It's the first time it was run in unknown amount of years and it was less than 1 minute of runtime.
I can't really ride it because the tires are old as hell with fault lines for dry rot cracks and loses air. Someone put a derp seat on it but I ordered a factory one to recover that's not rotted out. It's beat up and had one hole drilled into the frame to secure the seat. Looks like it came off a junkyard bike but the rest of the bike is clean. It needs to go.
Did the carbs come with the idle mixture screws uncovered because as far as I know that would be unusual. All jets were stock and in the correct carbs. Sorry for the long intro post Im just hoping I can get some good news. I'm a little worried about this noise. The bike was last owned by an older gentleman that unfortunately had a leg amputated and then later passed away. His family put the bike away until I bought it for $250 in non operational condition. Tried but didn't start off ether when I picked it up. Either way I'm happy to be the next owner of this motorcycle and hope I can ride it without it suddenly grenading on me causing wreck or something.
