When you remove the front wheel, you will see Allen Head bolts at the bottom of the fork, where the axle mounted too. Usually you need an electric drill, or air tool, to attach a socket to to remove them. On some forks, if you loosen them, they just spent with the corresponding locknut inside. The speed of the tool allows you to remove that bolt. That's what prevents the fork from coming out of the lower slider. Once you do that, removal of the seals with a flat head screw driver is quite easy. Wrap the screw driver in electrical tape around the shaft so you don't gouge the fork lower, and make sure you do not touch the inside of the for seal race on the lower leg. In other words, you only touch the seal, wedging it out by going around a little by little amount. Assembly is the reverse. I put a little high temperature great on the inside of the new fork seals, over the compression spring, to kep the inside of the seal lubed. Prevents squeaking of the forks. Forks are pretty much the same on all bikes.
