1 - 14 of 14 Posts
Hey y’all. Just picked up a 85 LTD 700. Need to dig in deep as my rear master cylinder is leaking but I will get there. Learning this is a pretty rare bike to have been chopped up but she’s beautiful and I am proud to have her
Wheel Tire Plant Fuel tank Vehicle
Administrator
I sincerely wish you the best of luck in finding a seal kit or a new rear brake cylinder.
Your bike and mine use the same piston and seal kit and I was unable to find a new one anywhere. If you do find a source please post it here. There are others who are in the same boat. I ended up shortening a new piston to make it fit. It was not an easy task but it worked.
Sometimes used ones show up on Ebay but I was worried they might be in the same or worse condition than mine.
I have her with an old Harley guy currently and he is rebuilding the cylinder with “other parts”
His words to me were “it’s already a Frankenstein so we are just gonna keep operating” I should have her back in a week or so. I trust this mechanic 100% so I will update when she is home.
Discussion Starter · #11 ·
found this. Not sure if the company is legit but…
Administrator
Yeah, Megazip listed parts for my ZN but they did not have it when I inquired. Apparently they take your money and then a week later tell you that part is no longer available. At least that's what some of the reviewers say about Megazip.
Luckily I did not place the order, and emailed them to check stock before I ordered. They responded within a few days to so, no, its no longer available.
But even if they have it, $324 USD? Yikes.
Administrator
I would look for a similar but newer brake cylinder and adapt it to your ZN. Motorcycle salvage yards are a good place to look. If there is one nearby, take your old one with you to find the best match. You might even find one that bolts right in.
I'd really try to rebuild the original Brake Cylinder. I have an old M.G., and after buying 3 that leaked, I just honed the old one, and let the seal swell up in some Brake fluid for 5 minutes (Brake fluid makes some rubber swell). It was a real p.i.a. to get in, but it hasn't leaked in 23 years.
p.s. That MEGZIP, I wouldn't deal with them. :)
1 - 14 of 14 Posts
