It is now 01h04 am there by you, (Zoro) 09h30 here in South Africa, DONT TELL ME YOU GUYS ARE SLEEPING.
The problem is,when I leave the airmixture screw at the correct setting,meaning the same as the other 3 carbs the no 2 header is not heating up at idling.
When I turn no 2 screw way out then no2 heats up.
I"v checked both jets and made sure they are clean and not clogged,so the possibility of dirt is now eliminated.
Could it be the valves or shims.
What trickles me is,I"v looked at the tiny hole right at the bottom where the air screw goes into the carb,can that amount of exctra air make such a differance.
