Nomad Charging System
2 reading
4.8K views 10 replies 7 participants last post by  ricksza
#1 ·
I have a 12 volt outlet installed on my 06 Nomad.
The main purpose is to keep my phone charged while riding during our 2 week tour since we won't have access to shore power.
I'll be carrying a sealed lead acid 10 Amp hour battery that I use to power a 12 Volt fan to help cool off in the tent when it's 90+ in the middle of July...
(works pretty well, we get 8+ hours of cool breeze before it gets run down!
It is a deep cycle style battery from an electric scooter).
Is the Nomad's charging system generous enough to charge the extra battery back up while riding each day, and is the regulator up to the task with the extra capacity?
The idea is to connect the spare battery to the charging system through the 12 Volt outlet with a double ended cord, safe and easy since the battery will ride in the side bag.
Rob
#2 ·
It shouldn't be a problem provided your outlet is connected directly to the battery with an in-line fuse and not sharing another circuit. Check your battery charger for it's amp draw, though, just to be safe and use the correct size fuse.
Try to get a charger that has auto-shutoff once the battery is full, if you can, otherwise make sure to disconnect it during any long rest periods.
#3 ·
Hi,
Thanks for the reply!
The outlet is wired to the accessory wires under the seat.
I'm not sure I understand what you mean about the "charger"?
I don't want to charge the motorcycle battery through the outlet, I want to use the motorcycles charging system, while riding, to charge the spare battery that I'll be storing in the saddle bag.
Rob
#4 ·
He's not using a charger, it seems he's basically doing the same as you would to jump start another vehicle.
#6 ·
Thanks!
Good advice about waiting until the bike is running.
I knew it will work in theory, just wasn't sure if the Nomad charging system was up to the task.
I've read about different bikes on the forums that seem to barely be able to keep up with themselves...and didn't want to cause myself more problems than I'm solving :)
Rob
#7 ·
Nomad has 2 alternators! One larger one and one smaller one as back up. As long as you don't hit the system with a dead battery it should be okay to parallel the second battery up to charge when you are on the Highway at speed!
#9 ·
I hope someone can awnswer this question.
Which alternator on the 1600 is #1 and which is #2? Is the one nearest the engine #1 or vice versa?
There are two plugs exiting the alternator case, they are the same BUT one plugs into a plug with three yellow wires and one plugs into a plug that has three yellow wires with black stripes.
Which one goes to the rear rectifier?
#10 ·
Hello All-new user and I have a question related to an 06 Kaw Nomad. When I start the bike the speedo climes to 140 and the fuel pump is screaming. Even with the bike sitting still I am still putting on miles due to the speedo registering speed.. Anyone have similiar problems like this? Thanks for any and all replies my friends.
#11 ·
I don't have the wiring schematic for your bike, but i would probably look at the ECU. Most likely the speed sensor is an input to the ECU which sends a signal to the speedometer. It might be picking up a reading from another sensor either before or inside the ECU. I think there was a recall for the ECUs in 06.
