Here is the info on the 1600 Nomad:
FEATURES
V-Twin Engine
- Engine displacement increased to 1,552cc for more torque
- Digital Fuel Injection is revised to suit the larger engine’s needs and enhance performance
- Dual mufflers allow more clearance for saddlebags
Liquid Cooling
- Maintains consistent engine temperatures for long engine life and sustained power during hard use
- Auxiliary fan keeps things cool during all operating conditions
Four Valves per Cylinder
- Boosts low-end torque
- Provides maximum valve area for optimum flow
- Hydraulic valve lash adjusters require no maintenance
Gear-driven Engine Balancer
- Counter-rotates at engine speed to cancel vibration
- Allows use of single-pin crankshaft without the heavy vibration
Rubber-mounted Engine
- All but eliminates engine vibration at all speeds
Five-speed Transmission
- Great around-town acceleration with relaxed highway cruising
Positive Neutral Finder
- Just lift the shift pedal from first at a stop to find neutral easily
Five-gallon Fuel Tank
- Rounded-edge finish for clean, upscale look
- Large capacity for extended touring range
Large, Adjustable Windshield
- Large windshield gives excellent rider and passenger weather protection
- Windshield is adjustable up and down two inches
- Heavy-duty chromed support hardware holds the windshield rock steady
Hard Saddlebags
- Designed for easy packing, these saddlebags carry an amazing amount of gear
- Lockable, side-open design for smooth looks and quick access
- Soft, removable inner bags available as an optional accessory
Passenger Comfort
- New floorboards, standard backrest and thicker seat provide maximum passenger comfort on long rides
More Chrome for 2005
- New chrome engine guards help protect the engine
Triple Disc Brakes
- Dual discs up front for maximum stopping power
- Large, single rear disc because touring bikes carry so much of the load on the rear wheel
Shaft Drive
- Reliable, clean and quiet low-maintenance system
Hydraulic Clutch Release
- Easy to operate, requires virtually no adjustment
Adjustable Control Levers
- Fits variety of rider sizes and styles
Electronic Speedometer
- Eliminates conventional cable-drive system
Tubeless Tires
- Lower operating temperature extends tire life
Air-Adjustable Rear Shocks
- Rebound damping is 4-way adjustable to tailor fit the ride
SPECIFICATIONS
Engine: Four-stroke V-twin, SOHC, 8-valve
Displacement: 1,552cc
Bore x stroke: 102.0 x 95.0mm
Compression ratio: 9.0:1
Cooling: Liquid
Carburetion: Digital fuel injection with (2) 36mm throttle bodies
Ignition: Digital
Transmission: Five-speed
Frame: High-tensile steel, double cradle
Rake / trail: 32 degrees / 7.2 in.
Suspension type, front: 43mm hydraulic fork
Suspension type, rear: Dual hydraulic shocks
Suspension adjustments, rear: Air adjustable twin shocks, 4-way rebound damping
Wheel travel, front: 5.9 in.
Wheel travel, rear: 3.9 in.
Tire, front: 150/80 x 16
Tire, rear: 170/70 x 16
Brakes, front / rear: Dual hydraulic 300mm discs / single 300mm disc
Overall length: NA
Overall width: NA
Overall height: NA
Ground clearance: 5.9 in.
Seat height: 28.4 in.
Dry weight: NA
Fuel capacity: 5.3 gal.
Wheelbase: 66.5 in.
Colors: Metallic Dark Blue, Ebony/Galaxy Silver
* Price and specifications subject to change
