1 - 14 of 14 Posts
I have run into a problem with my 01 800 classic. I changed the oil today, put on a new filter(mobil 1 110) fresh oil (3 quarts 20-50 valvoline) and when I started it up the oil and temp lights are on and won't go off. I got my wife to sit on it and lean it up after the first startup and the oil level was right in the middle in the sight glass. Now, if I lean it up and look I can't see any change. What is wrong? Thanks in advance for the replies.
I was at D.O.D #1!
Air pocket in the oil pump. First try opening the oil filler cap. If that does not work, try unscrewing the filter just a touch (quickly, or oil will make a mess, make sure you have a catch pan under it) and re-tighten.
20w50 is too heavy for a 800, it's not an air-cooled H-D. I'd run 10w40 or 15w40 (rotella) is what I use.
Like Mcwrath said, pump is air bound. Loosen filter a turn or two loose, crank engine for just a second, turn off it it starts, then tighten filter.
Discussion Starter #5
Took filter completely off and no oil in it!!! What has happened? Loosened it a bit and cranked and noticed nothing was coming out.
Discussion Starter #6
Fixed it! Got the wrong oil filter and the pump wouldn't pump through it! I guess I need to get a vulcan specific oil filter. Live and learn! Thanks youuns for your help! That's why I love this forum.
I would also heed the advice from Cosmicclassic about 20w50. It's far too heavy for that bike and most bikes for that matter. You'll notice it when you shift also.
Discussion Starter #9
I was checking on oil changing posts and found that a Mobil 1 110 would fit. Yeah, it fit but for some reason won't flow oil.
Discussion Starter #10
It really doesn't matter. The point is I learned something today about the oil pump and something it is capable of even if it wasn't my problem. If something similar like this happens again I have something else to check. Thanks for all the quick responses!
Nobody Home
That filter shouldn't be a problem. I've never airlocked an oil pump during an oil change and am wondering what people are doing to accomplish it.
Life Begins at 200 mph
I also agree with running 10w40 oil in that size of a bike. The 20 is suited more for hot climates. You live in Kentucky not Arizona.
20W-50 will be fine as long as you don't ride below 32 degrees I believe.
Discussion Starter #14
I had planned on doing a quick change anyway because I don't know what oil had been used previously. Thanks for the tips guys!
1 - 14 of 14 Posts
