1 - 1 of 1 Posts
I have a zn 1100 84 . I rebuilt the carbs all the way to new diaphrgams.
(big money) eekk!!
So here is the problem it ran fine till today now it is fouled out an there is oil driping out of the carbs near the air box . I do not want to fear the worst but there is no smoke coming from the exhaust so i do not think it is the rings or valve guides but i am at a loss to explain it but it is gumming up carbs an running on my block ????
any ideas??? they are cv carbs with no plungers very simple..
crank case breather clogged ???
I changed the oil an filter called kawasaki to get amount + used level window ..
that is all i can think of .
It does have the typical valve tick but it is not bad only at idle ...
HELP HELP HELP THE SEASON IS SHORT HERE..
1 - 1 of 1 Posts
