I have owned a 'D' reg GPZ600r for ~ 2 years. Recently noticed petrol blooms on the ground after bike had been standing, say overnight. Without the benefit of a h/book I managed to remove the tank, unfortunately I didn't get a note of where the two hoses were connected from the petrol tap to the carbs. There is a connection toward the front of the engine/carbs and another towards the rear. The original pipe configuration had an in-line fuel filter on one hose only, should this be the 'ON' or 'PRI'. If someone can advise where the 'PRI' and the 'ON'/'RES' outlet from the petrol tap go, and in which line the filter should be I'd appreciate it.
By the way, I think the leak was down to a perished end on one of the hoses, now sorted. Strangely (I think) there is no clips to secure the connection ends on any of the petrol pipes.
